[postgis-users] 3D spatial index and && 2d operator
Jose Carlos Martinez Llario
jomarlla at cgf.upv.es
Thu Dec 29 13:49:12 PST 2011
Dear list,
Im using PostGIS 2.0 trunk r 8612
In order to use 3d spatial index Im using the &&& operator and its
working well (thanks Paul) with the following 3d spatial index:
create index p3d_geom_gist on p3d using gist(geom gist_geometry_ops_nd);
but then I noticed that the 2d && operator is not using the 3d spatial
index (I confirmed it looking into the postgis.sql file). I can fix it
creating a second index on the same column like:
create index p3d_geom_gist2d on p3d using gist(geom);
but it seems to me a waste of resources.
I could use &&& operator with a huge z range imitating the && operator
but I dont like too much this solution.
Why the gist_geometry_ops_nd operator is not defining the && operator? I
guess it is because PostgreSQL can not know which one it should apply.
Anyways, this is going to be the expected behavior in the PostGIS 2.0
final release, I mean should we create two indexes on the same geometry
column for using && and &&& operators with spatial indexes?
Thanks,
PD: I dont know which is the appropiate list for the trunk PostGIS
questions, postgis-users or postgis-devel?
