[postgis-users] postgis visual client
j.rolland
jrmrolland at aol.com
Fri Feb 11 07:59:24 PST 2011
John,
MapWindow6 or .NET 4.0 don't need to be installed,
1) just download
http://dl.free.fr/icO8LcHoa PostGISViewer and decompress it like follow :
http://old.nabble.com/file/p30902546/directory_postgisviewer.jpg
2) define the binaries directory in PgAdmin III Preferences :
http://old.nabble.com/file/p30902546/preferences_pgadminIII.jpg
you can see that the PostGisViewer directory is in C:\Program
Files\PostgreSQL\9.0\bin
3) put the lines that follow in the plugins.ini file
; PgViewer (Windows)
[Separator]
Title=PostGisViewer
Command="$$PGBINDIR\PostGisViewer\PGViewer.exe" "host=$$HOSTNAME"
"port=$$PORT" "username=$$USERNAME" "password=$$PASSWORD"
"database=$$DATABASE" "schema=$$SCHEMA" "table=$$TABLE"
Description=PostGIS Viewer
KeyFile=$$PGBINDIR\PostGisViewer\PGViewer.exe
Platform=windows
ServerType=postgresql
Database=Yes
;AppliesTo=database
SetPassword=Yes
4) When you start again PgAdmin you must see PostGisViewer in the Plugins
Menu.
I am using PostgreSQL 9.0 and PgAdmin III 1.12.1 , but i had also tested my
plugin with Postgresql 8.2 /8.4 and PgAdmin III 1.10
regards,
Jérôme Rolland
John Callahan wrote:
> Thanks for the reference. I love the idea of a map viewer plugin for
> pgAdmin. I wasn't aware of this plugin. Unfortunately, I could not get
> it
> to work through pgAdmin III 1.12 (error: "pgviewer encountered a problem
> and
> needs to close") Off-hand, does it require MapWindow6 or .NET 4.0 to be
> installed?
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> On Thu, Feb 10, 2011 at 4:51 AM, j.rolland <jrmrolland at aol.com> wrote:
>> John,
>> I developed a plugin for PgAdmin III to visualize PostGIS data.
>> Go to the following link
>> http://ageoguy.blogspot.com/2010/06/plugin-pgadmin-iii-postgisviewer-suite.html
>> postgisviewer a plugin for PgAdmin III
>> on my blog where you can download it and you will find a tutorial (in
>> french) to install and use it.
>> You can also consult this link
>> http://www.postgresonline.com/journal/archives/180-pgAdmin113plugins_postgis.html
>> Postgresonline journal pgAdmin III plugins postgis
>> Regards,
>> Jérôme Rolland
>> > I'm sure this has been asked many times but haven't found a definitive
>> or
>> > consensus answer...
>> > Is there a postgis client that supports spatial, ad hoc queries and
>> > returns
>> > those results to a map? This would include simple (and more complex)
>> > SELECT
>> > statements but also other queries with spatial results, such as finding
>> > nearest neighbors, intersect, union, etc...
>> > The best idea I found was to create a view from the ad hoc query and
>> then
>> > use a desktop GIS to display that view. You'd need to update the view
>> > (and
>> > refresh the GIS screen) to run a new query. I know QGIS (and other
>> FOSS
>> > GIS packages) allows you to create a definition query (a where clause
>> to
>> > subset the layer) and does support database views. I haven't seen a
>> place
>> > where QGIS supports ad hoc queries. Searching the web, I did find
>> > references to some work done using OpenMap libraries back in 2004, and
>> the
>> > mezoGIS package from around 2005/2006.
>> > Does anyone know of a GUI tool to use, hopefully one that works for
>> > Postgres
>> > 9 and PostGIS 2? Thanks.
>> > - John
>> > PS - Thanks for the recommendations on the PostGIS in Action book. I
>> just
>> > purchased it and looking forward to learning what I can.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> View this message in context:
>> http://old.nabble.com/postgis-visual-client-tp30875438p30890812.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
View this message in context: http://old.nabble.com/postgis-visual-client-tp30875438p30902546.html
