[postgis-users] shp2pgsql with DBF >= 2 GB?
Aren Cambre
aren at arencambre.com
Sat Jan 1 10:06:45 PST 2011
Does it cause a regression for 32-bit users?
Aren
On Sat, Jan 1, 2011 at 11:16 AM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> On 64bit machines it works.
> P.
> On 2011-01-01, at 5:33 AM, Aren Cambre <aren at arencambre.com> wrote:
> It was raised there 4.5 years ago: <http://bugzilla.maptools.org/show_bug.cgi?id=1463>
> http://bugzilla.maptools.org/show_bug.cgi?id=1463.
> Might be nice if PostGIS maintainers could "bug" that developer about
> resolution?
> The proposed local patch is changing int to long on three variables. While
> that may not be graceful, could it work as a temporary workaround?
> <http://bugzilla.maptools.org/show_bug.cgi?id=1463>Aren
> On Sat, Jan 1, 2011 at 7:05 AM, Mark Cave-Ayland <<mark.cave-ayland at siriusit.co.uk>
> mark.cave-ayland at siriusit.co.uk> wrote:
>> On 01/01/11 06:46, Paul Ramsey wrote:
>> No workarounds. I thought there was a braindead patch on that ticket
>>> already, but it's not a patch I feel good enough to apply as a
>>> permanent fix.
>>> P.
>> Yeah. Also since we've recently resynced with upstream shapelib, I'd much
>> rather the issue is raised/fixed there and then we can just resync once
>> again.
>> ATB,
>> Mark.
>> Mark Cave-Ayland - Senior Technical Architect
>> PostgreSQL - PostGIS
>> Sirius Corporation plc - control through freedom
>> <http://www.siriusit.co.uk>http://www.siriusit.co.uk
>> t: +44 870 608 0063
>> Sirius Labs: <http://www.siriusit.co.uk/labs>
>> postgis-users mailing list
>> <postgis-users at postgis.refractions.net>
>> <http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110101/837e7ec4/attachment.html>
