[postgis-users] rookie question: how to extract latitude and longitude values from geography(POINT) column?
Robert_Clift at doh.state.fl.us Robert_Clift at doh.state.fl.us
Wed Jan 5 08:47:27 PST 2011
Hi Matt:
Believe you can cast your geography AS geometry within a query, like:
SELECT ST_X(myGeogColName::geometry), ST_Y(myGeogColName::geometry)
  FROM myTable;
-Rob
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of W. Matthew Wilson
Sent: Wednesday, January 05, 2011 11:30 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] rookie question: how to extract latitude and longitude values from geography(POINT) column?
On Wed, Jan 5, 2011 at 10:09 AM, David Fawcett <david.fawcett at gmail.com> wrote:
> I haven't tried them specifically with the geography type, but I would
> assume that ST_AsText(), ST_X(), and ST_Y() should work.
> Something like:
> SELECT ST_X(myGeogColName), ST_Y(myGeogColName)
>   FROM myTable;
Apparently ST_X wants a geometry point, not a geography point.  I tried this and it failed:
dev=> select ST_X(ST_GeogFromText('POINT(11 12)'));
ERROR:  function st_x(geography) does not exist LINE 1: select ST_X(ST_GeogFromText('POINT(11 12)'));
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
So then I converted the geography point into a geometry point, and it works OK:
dev=> select ST_X(ST_GeomFromText(ST_AsText(ST_GeogFromText('POINT(11 12)'))));
| st_x |
|   11 |
(1 row)
What is the right way to convert a geography point to a geometry point?  Is there something better / faster / safer than dumping to text and then reloading?
Thanks for the help.
Matt
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
