[postgis-users] rookie question: how to extract latitude and longitude values from geography(POINT) column?
W. Matthew Wilson
matt at tplus1.com
Wed Jan 5 08:30:23 PST 2011
On Wed, Jan 5, 2011 at 10:09 AM, David Fawcett <david.fawcett at gmail.com> wrote:
> I haven't tried them specifically with the geography type, but I would
> assume that ST_AsText(), ST_X(), and ST_Y() should work.
> Something like:
> SELECT ST_X(myGeogColName), ST_Y(myGeogColName)
> FROM myTable;
Apparently ST_X wants a geometry point, not a geography point. I
tried this and it failed:
dev=> select ST_X(ST_GeogFromText('POINT(11 12)'));
ERROR: function st_x(geography) does not exist
LINE 1: select ST_X(ST_GeogFromText('POINT(11 12)'));
HINT: No function matches the given name and argument types. You
might need to add explicit type casts.
So then I converted the geography point into a geometry point, and it works OK:
dev=> select ST_X(ST_GeomFromText(ST_AsText(ST_GeogFromText('POINT(11 12)'))));
| st_x |
| 11 |
(1 row)
What is the right way to convert a geography point to a geometry
point? Is there something better / faster / safer than dumping to
text and then reloading?
Thanks for the help.
Matt
