[postgis-users] Encoding error on shp2pgsql
Paul Ramsey
pramsey at opengeo.org
Thu Jan 6 16:06:26 PST 2011
Your shapefile attributes have hibit characters in them. As the error
message states, you might want to try a LATIN1 encoding (if your data
are western european) or perhaps another more appropriate encoding
(http://www.postgresql.org/docs/8.1/static/multibyte.html) if they are
not.
P
On Thu, Jan 6, 2011 at 3:42 PM, Dheeraj Chand <dheeraj at dheerajchand.com> wrote:
> Hello, all!
> First post, and it's a repeat of a question I was asking in the IRC channel.
> I'm having some trouble with shp2pgsql. I installed PostGIS 1.5.2 from
> source, on PostgreSQL 9.0.2, from source, and I think that I must have done
> something incorrectly, because when I try to load a shapefile into a
> database created according to the PostGIS template, I get an encoding
> error. I realise that the term output here is long, but would someone mind
> taking a look at it and confirming that I did this
> correctly? http://dheerajchand.pastebin.com/YaHt3kAp
> Thanks,
> -dx
> postgis-users mailing list
