[postgis-users] How to reproject data with custom projection?
Paul Ramsey
pramsey at opengeo.org
Sat Jan 8 21:34:03 PST 2011
Plug that WKT into http://prj2epsg.org and the answer appears to be EPSG:3082
http://prj2epsg.org/epsg/3082
P
On Sat, Jan 8, 2011 at 8:18 PM, Aren Cambre <aren at arencambre.com> wrote:
> I have a SHP with this in its PRJ file:
> PROJCS["Custom",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1500000.0],PARAMETER["False_Northing",5000000.0],PARAMETER["Central_Meridian",-100.0],PARAMETER["Standard_Parallel_1",27.5],PARAMETER["Standard_Parallel_2",35.0],PARAMETER["Central_Parallel",18.0],UNIT["Meter",1.0]]
> I need to get this into 3081 somehow since it's a good projection for Texas.
> I have some 3081-reprojected PoistGIS data (originally 4269) for Texas
> already. If I load this SHP into QGIS along with other 3081 data, it appears
> well below the other data. QGIS indicates this SHP has a custom projection.
> If I am not mistaken, to reproject with PostGIS, I need something besides -1
> in the geometry table. So I guess I need to specify some SRID with -s when I
> run shp2pgsql? If so, what projection is this?
> Thanks, and I apologize in advance for my naivety.
> Aren
> postgis-users mailing list
