[postgis-users] How to reproject data with custom projection?
Ben Madin
lists at remoteinformation.com.au
Sat Jan 8 21:35:08 PST 2011
Aren,
You need a reference projection, you are correct.
For the sake of the exercise, bookmark
http://spatialreference.org/
and then try the search box for parts of the string which are maybe unusual :
I tried
"Standard_Parallel_1",27.5 Lambert_Conformal_Conic
in the search box.
then I reckon you can probably choose any of the three results I get - there appears to be very little difference between them and your string.
If you haven't used this site before, looking at the
Well Known Text as HTML
Human-Readable OGC WKT
Proj4
OGC WKT
JSON
GML
ESRI WKT
.PRJ File
options will help.
Good luck (from the antipodes, so take your chances)
cheers
Ben
On 09/01/2011, at 3:18 PM, Aren Cambre wrote:
> I have a SHP with this in its PRJ file:
> PROJCS["Custom",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1500000.0],PARAMETER["False_Northing",5000000.0],PARAMETER["Central_Meridian",-100.0],PARAMETER["Standard_Parallel_1",27.5],PARAMETER["Standard_Parallel_2",35.0],PARAMETER["Central_Parallel",18.0],UNIT["Meter",1.0]]
> I need to get this into 3081 somehow since it's a good projection for Texas.
> I have some 3081-reprojected PoistGIS data (originally 4269) for Texas already. If I load this SHP into QGIS along with other 3081 data, it appears well below the other data. QGIS indicates this SHP has a custom projection.
> If I am not mistaken, to reproject with PostGIS, I need something besides -1 in the geometry table. So I guess I need to specify some SRID with -s when I run shp2pgsql? If so, what projection is this?
> Thanks, and I apologize in advance for my naivety.
> Aren
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110109/b8309131/attachment.html>
