[postgis-users] Create new lines from GPS points
Ralf Suhr
Ralf.Suhr at itc-halle.de
Tue Jan 11 08:38:26 PST 2011
Hi Martin,
you will not get a correct solution for this problem. Your road network and
the gps points differs always.
A possible "solution" is building a buffer around the streets und look für
intersection with gps points and filter by direction road/points. Grouping gps
points can give you the start and end point for the road. If a road is only
one times driven.
Gr
Ralf
Am Dienstag 11 Januar 2011, 17:16:18 schrieb Martin Fafard:
> Hi
> I have a network of roads (topological) and I receive GPS points. I
> would like to create new lines who follow exactly the same path as my
> road from the GPS points (to "highlight" where the GPS unit was on the
> network). The problem is I need to segment the new line because the GPS
> points can stop anywhere on my roads... Any advice to do this?
> Thank you
> Martin F
> postgis-users mailing list
