[postgis-users] Create new lines from GPS points
    Martin Fafard
    martin.fafard at geoprojection.com
    Tue Jan 11 08:46:06 PST 2011
Ralf
Yes, ok for the buffer. But how to "dynamically segment" my new road
from my original segment?
Martin
Ralf Suhr a écrit :
> Hi Martin,
> you will not get a correct solution for this problem. Your road network and
> the gps points differs always.
> A possible "solution" is building a buffer around the streets und look für
> intersection with gps points and filter by direction road/points. Grouping gps
> points can give you the start and end point for the road. If a road is only
> one times driven.
> Gr
> Ralf
> Am Dienstag 11 Januar 2011, 17:16:18 schrieb Martin Fafard:
>> Hi
>> I have a network of roads (topological) and I receive GPS points. I
>> would like to create new lines who follow exactly the same path as my
>> road from the GPS points (to "highlight" where the GPS unit was on the
>> network). The problem is I need to segment the new line because the GPS
>> points can stop anywhere on my roads... Any advice to do this?
>> Thank you
>> Martin F
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110111/408d9a6f/attachment.html>
