[postgis-users] Transform WGS84 to UTM
Birgit Laggner birgit.laggner at vti.bund.de
Wed Jan 12 01:59:52 PST 2011
  Hi Lelo,
yes, normally it's very simple. If you know the SRID of the projection
you want to transform your geometry to, you only have to use
ST_Transform(your_geometry_column, new_srid_number)
(see:
http://postgis.refractions.net/documentation/manual-1.5/ST_Transform.html)
If you don't know the new SRID, I suggest a search at
http://spatialreference.org/
Regards,
Birgit.
On 11.01.2011 20:01, Lelo wrote:
> Hi All,
> I'm starting to work with postgis and I have to transform geometries
> from WGS84 to UTM. Are there a simple way to do that using just the
> postgis?
> Thanks for all
> Rogério De Pieri  (Lelo)
> Buscando melhorar a cada dia
> Áudio, Hardware & Software
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110112/27b0958e/attachment.html>
