[postgis-users] Transform WGS84 to UTM
Mars Sjoden aurorageomatics at gmail.com
Wed Jan 12 23:12:24 PST 2011
Just a refresher,
WGS84 is a Datum
UTM is a Projection that can use WGS84 as its Datum
On Wed, Jan 12, 2011 at 1:59 AM, Birgit Laggner
<birgit.laggner at vti.bund.de>wrote:
>  Hi Lelo,
> yes, normally it's very simple. If you know the SRID of the projection you
> want to transform your geometry to, you only have to use
> ST_Transform(your_geometry_column, new_srid_number)
> (see:
> http://postgis.refractions.net/documentation/manual-1.5/ST_Transform.html)
> If you don't know the new SRID, I suggest a search at
> http://spatialreference.org/
> Regards,
> Birgit.
> On 11.01.2011 20:01, Lelo wrote:
> Hi All,
> I'm starting to work with postgis and I have to transform geometries from
> WGS84 to UTM. Are there a simple way to do that using just the postgis?
> Thanks for all
> Rogério De Pieri  (Lelo)
> Buscando melhorar a cada dia
> Áudio, Hardware & Software
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110112/dc6c166c/attachment.html>
