[postgis-users] Transform WGS84 to UTM
Paragon Corporation lr at pcorp.us
Thu Jan 13 12:30:20 PST 2011
There is also the function in the wiki that will give you an srid in UTM for
a given wgs 84 long lat point.
http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctionsDistance
Leo,
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mars
Sjoden
Sent: Thursday, January 13, 2011 2:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Transform WGS84 to UTM
Just a refresher,
WGS84 is a Datum
UTM is a Projection that can use WGS84 as its Datum
On Wed, Jan 12, 2011 at 1:59 AM, Birgit Laggner <birgit.laggner at vti.bund.de>
wrote:
Hi Lelo,
yes, normally it's very simple. If you know the SRID of the projection you
want to transform your geometry to, you only have to use
ST_Transform(your_geometry_column, new_srid_number)
(see:
http://postgis.refractions.net/documentation/manual-1.5/ST_Transform.html)
If you don't know the new SRID, I suggest a search at
http://spatialreference.org/
Regards,
Birgit.
On 11.01.2011 20:01, Lelo wrote:
Hi All,
I'm starting to work with postgis and I have to transform geometries from
WGS84 to UTM. Are there a simple way to do that using just the postgis?
Thanks for all
Rogério De Pieri  (Lelo)
Buscando melhorar a cada dia
Áudio, Hardware & Software
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110113/fe2346b9/attachment.html>
