[postgis-users] Build PostGIS 1.5.2 under Windows
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Jan 19 05:45:09 PST 2011
On 19/01/11 13:27, Ilie, Radu wrote:
> I am not familiar with the MingW builds. If we do use them, will the
> resulting dll's have any dependencies on any runtime component of MingW?
> Or can we simply take the resulting dll's (for postgis, geos, proj etc)
> and copy them to another Windows system that doesn't have any part of
> MingW installed?
> Radu
You can check yourself with DEPENDS.EXE, but normally the only
dependency is the standard MSVCRT.DLL runtime supplied with Windows.
Possibly newer versions may have one additional DLL dependency for debug
stack handling.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
