[postgis-users] Calculation distance between two points
iKey
eike.lueders at gmail.com
Wed Jan 19 07:11:31 PST 2011
Hi Nicklas,
thanks for your reply.
Your second version with casting to geographic coordinates works fine for
me. :)
I think on my own I'd never found this solution. ;)
Many thanks again!!
Best regards
Eike
Nicklas Avén wrote:
> Hallo Eike
> The issue here is, latitude-longitude vs longitude-latitude.
> In PostGIS the order is longitude latitude
> So if you reverse the order of the coordinates you will get about 539
> meters.
> What is right or wrong depends on which one is longitude and which one
> is latitude.
> Another way to write your query in 1.5 is casting to geography
> So, to compare the two orderings:
> SELECT
> ST_Distance('POINT(52.278888888889
> 8.0430555555556)'::geography,'POINT(52.2812598 8.036165)'::geography),
> ST_Distance('POINT(8.0430555555556
> 52.278888888889)'::geography,'POINT(8.036165 52.2812598)'::geography)
> HTH
> Nicklas
> On Wed, 2011-01-19 at 06:40 -0800, iKey wrote:
>> Dear Community,
>> I want to calculate the distance between two points with a postgres
>> query.
>> The point reference system of my DB is epsg 4326. As far as I know I have
>> to
>> transform them, because with
>> WGS84 4326 I can calculate the distance in radian only.
>> This is an example query in that I try to calculate the distance in
>> different ways, but with no luck so far :(
>> SELECT ST_Distance(ST_Transform(ST_GeomFromText('POINT(52.278888888889
>> 8.0430555555556)',4326),
>> 900913),ST_Transform(ST_GeomFromText('POINT(52.2812598 8.036165)', 4326),
>> 900913))
>> ,ST_Distance_Sphere(ST_GeomFromText('POINT(52.278888888889
>> 8.0430555555556)',4326), ST_GeomFromText('POINT(52.2812598 8.036165)',
>> 4326))
>> ,ST_Distance_Spheroid(ST_GeomFromText('POINT(52.278888888889
>> 4326), 'SPHEROID["WGS 84",6378137,298.257223563]')
>> FROM pois
>> LIMIT 1;
>> The results look like this
>> 818.392971975843;
>> 809.44384291019;
>> 805.637737963218
>> When i calculate the distance in GoogleEarth or GoogleMaps I get a result
>> about 538,06m, so I think there is going something wrong in my
>> calculation with postgres.
>> Does anyone has any ideas whats going wrong or what else I can try?
>> Best regards
>> Eike
> postgis-users mailing list
View this message in context: http://old.nabble.com/Calculation-distance-between-two-points-tp30710456p30710748.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
