[postgis-users] Help with a multipolygon filtering function
Ross Lawley ross.lawley at gmail.com
Wed Jan 19 13:56:46 PST 2011
I want to clean up some multipolygons and remove any polygons over a certain
distance by using a postgis function.
This is the closest I've come:
    CREATE OR REPLACE FUNCTION filter_polygons_within(geometry, double
precision)
      RETURNS geometry AS
    $BODY$
    SELECT ST_Multi(ST_Collect(final_geom.poly)) AS filtered_geom
    FROM (
        SELECT DISTINCT a.poly
        FROM (
            SELECT ST_GeometryN(ST_Multi($1), generate_series(1,
ST_NumGeometries(ST_Multi($1)))) AS poly,
            (SELECT ST_GeometryN(ST_Multi($1), generate_series(1,
ST_NumGeometries(ST_Multi($1))))) as poly_b
        ) AS a
        WHERE a.poly != a.poly_b
        AND ST_DWithin(a.poly, a.poly_b, $1)
    ) as final_geom
    $BODY$
    LANGUAGE 'sql' IMMUTABLE;
However, the where clause isn't working for me - any ideas on how to achieve
this?  I'm not sure on how to compare all polygons with each other, I know
how to get a list of polygons;
I'm just not sure how to compare each one with another and return the
distinct polygon results.
Thanks in advance,
Ross
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110119/c491c5ae/attachment.html>
