[postgis-users] Coordinates and SRID - bound overflow, ST_Equals
Ilie, Radu rilie at wsi.com
Thu Jan 20 07:02:19 PST 2011
Doug,
There are cases where we need to use a difference branch of longitude values, e.g. 0 to 360, rather than -180 to 180.  For example, if one has a polygon that spans the international dateline, and one uses longitude from -180 to 180, some vertices of the polygon will have longitudes near 180, while others will have longitudes near -180.  When drawn as a Cartesian GEOMETRY, this will contain lines that span the entire earth.
To work around the limitation of Cartesian geometries for polygons and lines, we sometimes use longitudes from 0 to 360 and other times use longitudes from -180 to 180, depending on where the geometries are located.  Because our geometries span the globe, we cannot use either of these branches of longitude exclusively.
We want to convert these geometries to geographies to avoid the Cartesian limitation, and it would be nice if the transformation could be automatic through the casting function.
Radu
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Doug_Newcomb at fws.gov
Sent: Thursday, January 20, 2011 9:23 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Coordinates and SRID - bound overflow, ST_Equals
Radu,
        I am somewhat confused.  From my somewhat limited understanding of EPSG:4326 it's limited to values between 180, -180 for longitude and 90,-90 for latitude.  If your source geometry is epsg:4326, there should not be values outside of those limits.  Are you wrapping around those limits in your geometry column to accomodate lines/polygons  that cross those boundaries ? ( Stretching my brain a bit here)  Can you give examples of coordinates that you have that are exceed these limits?
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior.   Life is too short for undocumented, proprietary data formats.
"Ilie, Radu" <rilie at wsi.com>
Sent by: postgis-users-bounces at postgis.refractions.net
01/20/2011 08:33 AM
Please respond to
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
To
"PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
cc
Subject
Doug,
We do have the same problem. We are in a situation where a central server has a column of type geometry (SRID 4326) and it has points with latitude/longitude outside of (-180 -90,180 90). We need to retrieve the values from this column and insert them into a local server where the column is of type geography. It doesn’t work, we get errors like this:
ERROR:  Coordinate values are out of range [-180 -90, 180 90] for GEOGRAPHY type
Our solution for now is to modify the PostGIS code and normalize points outside of (-180 -90,180 190) during the cast to geography.
The solution is cumbersome, because it requires us to build PostGIS from source under Windows (the local server is Windows 7). And that is a science project in itself.
For reasons outside our control we cannot change the type of the column on the central server, nor can we move the local server to Linux. Is there any way to use the existing functions in PostGIS to normalize points outside the allowed range for geography? We need something that can be used during an implicit cast.
Radu Ilie
Sent: Thursday, January 20, 2011 8:02 AM
Balint
Would using the geography data type be more suitable to what you are trying to accomplish?
http://postgis.refractions.net/docs/ch04.html#PostGIS_GeographyVSGeometry <http://postgis.refractions.net/docs/ch04.html#PostGIS_GeographyVSGeometry>
Doug Newcomb
USFWS
Raleigh, NC
Balint Persics <persicsb at gmail.com>
01/20/2011 06:30 AM
Please respond to
To
cc
Subject
I have a very interesting problem, but I think some of you may have a
solution for that.
When I try to model Russia with EPSG:4326 coordinates, I "run out of
the bounds", e.g.  Russia's extent is so wide, it overlaps the
-180/+180 coordinate range of EPSG:4326, so the most
eastern part is in the western Hemisphere. When inserting points to
the geometry column, PostGIS allows me to insert both (186,45) and
(-174,45) (the former is out of the bounds of the reference, the
latter is okay). When I query the database whether these two points
are equal with ST_Equals, I get a false result , but in reality, they
are the same. I think there should be a version of ST_Equals which
compares the geometries taking into account their SRID.
Thanks,
Balint
Persics Balint
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users <http://postgis.refractions.net/mailman/listinfo/postgis-users> _______________________________________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110120/b2730c1d/attachment.html>
