[postgis-users] Why use C procedurals for Postgres
Nicklas Avén nicklas.aven at jordogskog.no
Fri Jan 21 06:13:52 PST 2011
Hallo
You should not need do change any security settings that is default in
PostgreSQL to run PostGIS.
But if there is some security setting that that is customized to not
allow C-langage functions there will be problems since PostGIS is
written in C.
But if you have not customized any security settings in PostgreSQL this
is just a symptom of something els.
What OS are you running?
/Nicklas
On Fri, 2011-01-21 at 13:44 +0000, Rudy COMMENGE wrote:
> Hello,
> I have installed Postgis with PostgreSQL.
> When I try to send postgis.sql to PostgreSQL, I have an error
> notifying C is not trusted.
> So I think I have found a solution : I disable the security with this
> request "UPDATE pg_language SET lanpltrusted=true WHERE lanname='c';"
> But this is a security, so is there another solution without disable ?
> If not, why Postgis need to bypass a PostgreSQL security ?
> Regards,
> RudyWI
> postgis-users mailing list
