[postgis-users] Why use C procedurals for Postgres
Rudy COMMENGE rudy_commenge at hotmail.com
Fri Jan 21 06:22:53 PST 2011
I'm on RedHat 5 Enterprise.
I have installed PostgreSQL 8.4.2 and Postgis 1.5.2
I have not customized PostgreSQL or Postgis installation.
> From: nicklas.aven at jordogskog.no
> To: postgis-users at postgis.refractions.net
> Date: Fri, 21 Jan 2011 15:13:52 +0100
> Subject: Re: [postgis-users] Why use C procedurals for Postgres
> Hallo
> You should not need do change any security settings that is default in
> PostgreSQL to run PostGIS.
> But if there is some security setting that that is customized to not
> allow C-langage functions there will be problems since PostGIS is
> written in C.
> But if you have not customized any security settings in PostgreSQL this
> is just a symptom of something els.
> What OS are you running?
> /Nicklas
> On Fri, 2011-01-21 at 13:44 +0000, Rudy COMMENGE wrote:
> > Hello,
> > I have installed Postgis with PostgreSQL.
> > When I try to send postgis.sql to PostgreSQL, I have an error
> > notifying C is not trusted.
> > So I think I have found a solution : I disable the security with this
> > request "UPDATE pg_language SET lanpltrusted=true WHERE lanname='c';"
> > But this is a security, so is there another solution without disable ?
> > If not, why Postgis need to bypass a PostgreSQL security ?
> > Regards,
> > RudyWI
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110121/15bf404e/attachment.html>
