[postgis-users] WKTRaster problems on Mac
knussear
knussear at mac.com
Tue Jan 25 11:19:24 PST 2011
I'm not an open Jump user, so I haven't explored any of these options
Paragon Corporation-2 wrote:
> Ken,
> Did you use the theming features of OpenJump. That is what we usually use
> to see the output.
> Here is a snapshot from the latest revision of our raster chapter of our
> upcoming book (due out hopefully in Mid-late February in print).
> Which is the output of this query (a raster intersected with a 100 meter
> radius buffer) after we apply a gradient theme.
> SELECT CAST((gval).val As integer) AS val,
> ST_AsBinary((gval).geom) As geom
> FROM (
> SELECT ST_Intersection(rast,1,buf.geom) As gval
> FROM ch13.kauai
> INNER JOIN (
> SELECT ST_Buffer(
> ST_GeomFromText('POINT(444205 2438785)',26904),100)
> As geom) As buf ON
> ST_Intersects(rast,buf.geom)) As foo
> Also BTW: Didn't see an image attached to your email.
> Also I recall OJ has some issues with double precision and long int which
> is
> why we cast it to an integer
> Hope that helps,
> Regina and Leo
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> knussear
> Sent: Tuesday, January 25, 2011 7:58 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] WKTRaster problems on Mac
> I did finally get the Open Jump call to work, and can see the polygon
> output. However its not entirely useful as I intend to use map algebra etc
> on the raster......
> The attachment from qgis shows the original input raster on top of what
> qgis shows for the raster. The qgis image of the postgis raster alone is
> just all green (gray etc).
> Ken
> Pierre Racine-2 wrote:
>> Actually the image in the previous post is the original. Attached is
>> what he sees when viewing the image in QGIS after it was imported in
>> PostGIS raster...
>>>[mailto:postgis-users- bounces at postgis.refractions.net] On Behalf Of
>>>Pierre Racine
>>>Sent: 24 janvier 2011 16:45
>>>To: PostGIS Users Discussion
>>>No but his first attempt was to open the image in QGIS. See the first
> mail. I attach the image he sent
>>>me as it was not attached in the first mail sent to users-postgis.
>>>I think this is typical of the first problem you met with the driver.
>>>Pierre
>>>>The GDAL driver is not being used in the commands I've seen. Did you
>>>>execute the query Pierre suggested?
>>>>SELECT ST_AsBinary((gv).geom), (gv).val FROM (SELECT
>>>>ST_DumpAsPolygons(rast) gv FROM x01) foo
>>>>Replacing "x01" by your table's name.
>>>>Jorge Arévalo
>>>>Internet & Mobilty Division, DEIMOS
>>>>jorge.arevalo at deimos-space.com
>>>>http://mobility.grupodeimos.com/
>>>>http://gis4free.wordpress.com
>>>>http://geohash.org/ezjqgrgzz0g
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://old.nabble.com/WKTRaster-problems-on-Mac-tp30721572p30755095.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
View this message in context: http://old.nabble.com/WKTRaster-problems-on-Mac-tp30721572p30761033.html
