[postgis-users] Create circles using a formula
Ben Madin
lists at remoteinformation.com.au
Wed Jun 1 18:17:57 PDT 2011
You could try :
http://postgis.refractions.net/documentation/manual-1.5/ST_Buffer.html
You might need something like :
ST_MakePolygon(ST_ExteriorRing(ST_Buffer(tower.point, resultOfDistanceFunction)))
cheers
Ben
On 02/06/2011, at 3:55 AM, vikashvikky wrote:
> Hi,
> I am doing a project for a telecom company. I have to render circles on the
> map(assuming the center of the circle as tower and circle as the area
> covered by that signal), I am using base layers as Google Maps,Yahoo
> maps(Spherical Mercator) So I have used CreateGeodesicPolygon() successfully
> to create circles by reading the values from DB.
> Now Since I have to render lot of circles, it made me switch to geoserver.
> Since the data is being provided by telecom company , they provide
> Lat,Lon,Gt,Gr,Pt,Pr,lambda(I think their meaning is irrelevant here) values.
> These values are stored in the database as they are. Now should use a
> equation(FRIIS transmission equation) and substitute each row(of a tower)
> values to find the distance covered by the tower.Then I have to create
> circles with that distance(considered as radius) and lon/lat and render them
> on map using geoserver.
> Please suggest me any ideas of how to carry on this task.... I wud be
> thankful to your guidance
> View this message in context: http://old.nabble.com/Create-circles-using-a-formula-tp31752667p31752667.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
