[postgis-users] ST_OffsetCurve
Sandro Santilli
strk at keybit.net
Wed Jun 29 02:29:46 PDT 2011
On Wed, Jun 29, 2011 at 11:17:39AM +0200, Stephan Holl wrote:
> Andreas Neumann <a.neumann at carto.net>, [20110629 - 11:11:33]
> > I hope that someone else can pay for the single-sided buffer to be
> > available in Postgis? Any takers?
> I thought that this was included in the estimation from strk as well?
> The initallay mentioned patch provided this already, but needs to get
> reworked as well as added tests and documentation.
The problem arised from a confusion about the term "single-sided buffer".
Rafalmag, author of the initial patch, called "single-sided buffer"
a function that would return a line, not an area.
Such a lineal output was (by Martin Davis of JTS, Paul and me) seen as
best called "offset curve" instead, whereas "single-sided buffer" would
be a function returning an area instead. See the first comments exchange
on http://trac.osgeo.org/postgis/ticket/413
Later on Martin implemented proper "single-sided buffer" (areal) in
JTS, which I ported to GEOS-3.3.0 as far as to the C-API, where I also
exposed a proper "GEOSOffsetCurve" with a good signature to replace
the badly named "GEOSSingleSidedBuffer" on which rafalmag patch is based.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
