[postgis-users] Convert from 3067 to 2393
Ralf Suhr
Ralf.Suhr at itc-halle.de
Fri Mar 4 03:46:39 PST 2011
Hi Pena,
first verify EPSG:2393 is set with correct towgs84 parameters in
spatial_ref_sys (http://spatialreference.org/ref/epsg/2393/proj4/).
Because the destination EPSG is not based on WGS84 ellipsoid you have to
transform twice: ST_Transform( ST_Transform( POINT_FROM_3067, 4326), 2393)
Gr
Ralf
Am Freitag 04 März 2011, 11:53:44 schrieb Pena Kupen:
> Hello all,
> I try to do some conversion between different coordinates (3067 to 2393 )
> without saving them to database. My sql is following:
> select x(ST_Transform(tbl.p,2393)), y(ST_Transform(tbl.p,2393)) from
> (select GeomFromText('POINT(108043 6683685)',3067) as p) as tbl
> result:
> 3107866.533 6686516.654
> Correct one is:
> 3108053.305 6686493.081
> location is about 200m too much on west.
> Any ideas?
> BRH
