[postgis-users] Fw: Re: Convert from 3067 to 2393
Pena Kupen
kupen at wippies.fi
Fri Mar 4 04:17:14 PST 2011
Ralf,
On our spatial_ref_sys at 2393 there is proj4text as
+proj=tmerc +lat_0=0 +lon_0=27 +k=1.000000 +x_0=3500000 +y_0=0 +ellps=intl +units=m +no_defs
It seems that +towgs4 is missing? If I change this, it it safe?
Do you mean like this?
select x(ST_Transform(ST_Transform( tbl.p, 4326),2393)), y(ST_Transform(ST_Transform( tbl.p, 4326),2393)) from
(select GeomFromText('POINT(108043 6683685)',3067) as p) as tbl
Result is same as before as:
3107866.533 6686516.654
Pena
Ralf Suhr [Ralf.Suhr at itc-halle.de] kirjoitti:
> Hi Pena,
> first verify EPSG:2393 is set with correct towgs84 parameters in
> spatial_ref_sys (http://spatialreference.org/ref/epsg/2393/proj4/).
> Because the destination EPSG is not based on WGS84 ellipsoid you have to
> transform twice: ST_Transform( ST_Transform( POINT_FROM_3067, 4326), 2393)
> Gr
> Ralf
> Am Freitag 04 März 2011, 11:53:44 schrieb Pena Kupen:
> > Hello all,
> > I try to do some conversion between different coordinates (3067 to 2393 )
> > without saving them to database. My sql is following:
> > select x(ST_Transform(tbl.p,2393)), y(ST_Transform(tbl.p,2393)) from
> > result:
> > Correct one is:
> > 3108053.305 6686493.081
> > location is about 200m too much on west.
> > Any ideas?
Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
