[postgis-users] TIN from point coverage
Olivier Courtin
olivier.courtin at oslandia.com
Thu Mar 24 15:17:21 PDT 2011
On Mar 24, 2011, at 10:52 PM, Pierre Racine wrote:
Pierre,
> My goal is to define the way leading from a point coverage to a
> raster. Something like ST_Interpolate("pointgeomtable",
> "rastercolumn") -> raster. What would be the step leading to that?
> I guess we have everything now to store a Delaunay Triangulation as
> polyhedral surfaces right?
Hum yes and no, in fact it depends :)
As i said the TIN model is designed for a feature model storage (CIM
use case),
so in a single cell, a reasonable small TIN (i.e thousands of points
is fine
or even more, but not a whole LIDAR Coverage triangulation)
If we want to handle this use case, i think
we have to add a way to split and aggregate a big TIN into several
small ones
(as i recall it should be the way Oracle Spatial handle it)
> Then from this polyhedral surface we can derive a raster...
> Maybe a first ST_AsDelaunayTriangulation(geom) could be an aggregate
> SET function returning a set of triangle...
Yes, if you produce a set of Triangles rather than a single huge TIN,
it could works with the current TIN implementation.
Question: is it something liblas could already handle ?
> and maybe ST_Interpolate(polyhedral surfaces) could be an aggregate
> function that would aggregate those triangle into a raster?
Olivier
