[postgis-users] Update column to nearest neighbor's value using subselect
Ben Madin lists at remoteinformation.com.au
Fri May 13 17:43:25 PDT 2011
Pete,
I'm not very good at these, but I don't think you have specified your columns enough in the subselect. There isn't any relationship between this query
>     SELECT b.tornado_index
>     FROM working.zip_tornado_index b
>     WHERE b.tornado_index IS NOT NULL
>     AND ST_DWithin(the_geom,b.the_geom,0.1)
>     ORDER BY ST_Distance(the_geom,b.the_geom) ASC NULLS LAST
>     LIMIT 1
and the insert. Does this return the same value every time?
By this I mean, you have the_geom in your subselect, but no reference to a table outside the subselect. If you run this query,
> UPDATE working.zip_tornado_index z
> SET tornado_index = (
>     AND ST_DWithin(z.the_geom,b.the_geom,0.1)
>     ORDER BY ST_Distance(z.the_geom,b.the_geom) ASC NULLS LAST
>     LIMIT 1
> WHERE tornado_index IS NULL;
is the result any different? Other's can probably help more than I.
cheers
Ben
On 14/05/2011, at 5:13 AM, Pete Yunker wrote:
> I have a table containing tornado index values by zip code.  A small number of the zip codes do not have values.  I would like to update the tornado_index values for those records by simply using the value for the nearest zip_code (by comparing distance to the centroid) in the same table.  The UPDATE statement that I use executes, but it appears to return the same record from the sub-select each time.  Doesn't the sub-select get executed for each record, as it depends on a value (the_geom) from the outer table?  Is there a better way to do this?
> -- Using postgres 8.3.6 and postgis 1.3
> -- working.zip_tornado_index --
> id                    int
> zip_code              text
> tornado_index         int
> the_geom              geometry (SRID=4326)
>     LIMIT 1
> Thanks,
> Pete
> postgis-users mailing list
