[postgis-users] Google Maps API with PostGIS
Ahmad Aburizaiza ahmadoa4 at gmail.com
Mon May 30 10:51:32 PDT 2011
Hello all,
I am fairly new to PostGIS and I have to work on a project for my PhD. I
hope you can help me. I want to build a web map where the user can select a
building or more than one from a layer on top of Google Maps API and the
code should create an automatic convex hull from the set of points generated
from the selected polygon(s). I am not sure on what to use but I have
general ideas and I do not know which is the best :
   - Do I use Google Maps API and PostGIS without needing a WMS or WFS?
   - Do I have to use with Google Maps API a WMS or a WFS?
And if someone has beneficial samples I can use to build the website, I
would really appreciate it.
Thank you in advance.
Ahmad Aburizaiza
PhD student at **George Mason University**
 Geography and Geoinformation Science Department
Fairfax, VA, USA
Tel : +1-703-981-0354*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110530/202e6db3/attachment.html>
