[postgis-users] Google Maps API with PostGIS
Dave dave.potts at pinan.co.uk
Mon May 30 11:33:23 PDT 2011
On 30/05/2011 18:51, Ahmad Aburizaiza wrote:
Perhaps you need to look at something like mapserver or geoserver
Both of these application are used as part of a web server either tomcat
or apache.  The will connect to postgis and provide access to your table
as wms/wfs server.
You can use something like openlayers to provide any pretty front end/
drawing of shapes etc.
D.
> Hello all,
> I am fairly new to PostGIS and I have to work on a project for my PhD.
> I hope you can help me. I want to build a web map where the user can
> select a building or more than one from a layer on top of Google Maps
> API and the code should create an automatic convex hull from the set
> of points generated from the selected polygon(s). I am not sure on
> what to use but I have general ideas and I do not know which is the best :
>     * Do I use Google Maps API and PostGIS without needing a WMS or WFS?
>     * Do I have to use with Google Maps API a WMS or a WFS?
> And if someone has beneficial samples I can use to build the website,
> I would really appreciate it.
> Thank you in advance.
> Ahmad Aburizaiza
> PhD student at **George Mason University**
> Geography and Geoinformation ScienceDepartment
> Fairfax, VA, USA
> Tel : +1-703-981-0354 <tel:703-981-0354>*
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110530/c84f9e31/attachment.html>
