[postgis-users] ST_Intersects Error
Bborie Park
bkpark at ucdavis.edu
Tue Nov 1 10:06:54 PDT 2011
On 11/01/2011 08:50 AM, elliott wrote:
> Thanks for the response. I have upgraded to PostGIS r8074 and restarted
> the database but still having the same problem.
When you upgraded, did you upgrade the sql functions as well? I believe
there is an upgrade script (rtpostgis_upgrade_20_minor.sql) that you'll
want to run. If you only upgraded the backend, that won't resolve your
problem as that error comes from a pure plpgsql function.
-bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
