[postgis-users] ST_Intersects Error
elliott
elliott at cpi.com
Tue Nov 1 08:50:50 PDT 2011
Thanks for the response. I have upgraded to PostGIS r8074 and restarted
the database but still having the same problem.
On 11/1/2011 10:43 AM, Bborie Park wrote:
> On Tue, Nov 1, 2011 at 7:10 AM, elliott<elliott at cpi.com> wrote:
>> I am getting the following error when using the ST_Intersects function in
>> this query:
>> STATEMENT: select ST_Value(rast, ST_Transform(ST_SetSRID(ST_Point(126.5,
>> 37.5), 4326), ST_SRID(rast))) from srtm3 where ST_Intersects(rast,
>> ST_Transform(ST_SetSRID(ST_Point(126.5, 37.5), 4326), ST_SRID(rast)));
>> ERROR: lower bound of FOR loop cannot be null
>> CONTEXT: PL/pgSQL function "_st_intersects" line 97 at FOR with integer
>> loop variable
>> I am not sure what it is complaining about. Any help would be greatly
>> appreciated.
> What revision are you running? Based upon your query and the error
> message, I believe the PostGIS revision you are running is out of
> date. The function signature for ST_Intersects changed recently (~ 1
> month ago) and I resolved that exact error you're getting in r7975.
> So, please do upgrade to at least r7975.
> -bborie
