[postgis-users] ST_Intersects Error
elliott
elliott at cpi.com
Tue Nov 1 11:24:32 PDT 2011
I believe my query was incorrect with an "extra" parameter for the
ST_Intersects call. Without the extra parameter, the query works just
fine now. Thanks for your help!
select ST_Value(rast, ST_Transform(ST_SetSRID(ST_Point(126.5, 37.5),
4326), ST_SRID(rast))) from srtm3 where ST_Intersects(rast, *1*,
ST_Transform(ST_SetSRID(ST_Point(126.5, 37.5), 4326), ST_SRID(rast)));
On 11/1/2011 2:20 PM, Bborie Park wrote:
> On 11/01/2011 10:32 AM, elliott wrote:
>> No, I had not updated the sql functions. With that update, I am now
>> getting a different error:
>> 4326), ST_SRID(rast))) from srtm3 where ST_Intersects(rast, 1,
>> ERROR: function st_asraster(geometry, double precision, double
>> precision) is not unique at character 8
>> HINT: Could not choose a best candidate function. You might need to add
>> explicit type casts.
>> QUERY: SELECT ST_AsRaster(geom, scale, scale)
>> CONTEXT: PL/pgSQL function "_st_intersects" line 14 at assignment
>> SQL function "st_intersects" statement 1
> Interesting. Can you try r8077? I've made a tweak that should
> eliminate the error. What version of PostgreSQL are you running? I
> haven't seen this error with 8.4, 9.0 or 9.1 in Linux.
> -bborie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111101/76730a69/attachment.html>
