[postgis-users] Slow Query Times for Split Tiles
elliott
elliott at cpi.com
Wed Nov 2 11:13:40 PDT 2011
Thanks for the suggestion. From the output, it doesn't look like it is
using the index even though an index was created with the
raster2pgsql.py script. Is there a specific way to tell the query to
use the index?
ENVDB=# EXPLAIN ANALYZE VERBOSE select ST_Value(rast,
ST_Transform(ST_SetSRID(ST_Point(126.5, 37.5), 4326), ST_SRID(rast)))
from srtm3 where filename='N37E126.hgt' AND ST_Intersects(rast,
ST_Transform(ST_SetSRID(ST_Point(126.5, 37.5), 4326), ST_SRID(rast)));
QUERY PLAN
Seq Scan on public.srtm3 (cost=0.00..23.90 rows=1 width=32) (actual
time=73.355..73.374 rows=1 loops=1)
Output: st_value(rast, 1,
st_transform('0101000020E61000000000000000A05F400000000000C04240'::geometry,
st_srid(rast)), true)
Filter: ((srtm3.filename = 'N37E126.hgt'::text) AND
((srtm3.rast)::geometry &&
st_srid(srtm3.rast))) AND _st_intersects(srtm3.rast,
st_srid(srtm3.rast)), NULL::integer))
Total runtime: 73.429 ms
(4 rows)
On 11/1/2011 8:43 PM, Michael Smedberg wrote:
> You can use the EXPLAIN command
> (http://www.postgresql.org/docs/8.4/static/sql-explain.html) to see
> what indices are used to execute a SQL statement.
> On Tue, Nov 1, 2011 at 2:42 PM, elliott <elliott at cpi.com
> <mailto:elliott at cpi.com>> wrote:
> I know that the tiles are indexed. How do I tell if the query is
> using the index?
> On 11/1/2011 5:34 PM, Pierre Racine wrote:
> Did you check if your query is using the index?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>
> [mailto:postgis-users- <mailto:postgis-users->
> <mailto:bounces at postgis.refractions.net>] On Behalf Of elliott
> Sent: Tuesday, November 01, 2011 4:48 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Slow Query Times for Split Tiles
> On 11/1/2011 4:27 PM, Mateusz Łoskot wrote:
> On 1 November 2011 20:23, elliott<elliott at cpi.com
> Should splitting raster files into tiles increase
> query performance?
> I have a two 1201x1201 raster tiles that were
> loaded by the following
> scripts:
> raster2pgsql.py -a -r N37E126.hgt -F N37E126 -t
> srtm3 -s 4326
> -k1201x1201> srtm.sql psql -f srtm.sql TEST
> raster2pgsql.py -a -r N37E127.hgt -F N37E127 -t
> srtm3 -s 4327
> -k50x50> srtm.sql psql -f srtm.sql TEST
> Querying these raster files appears to produce
> approximately the same
> timing results. Should the 50x50 have better
> performance than the
> 1201x1201?
> Taking almost 3 minutes to query 10000 points
> seems to be very slow.
> Do you query tiles or points (what points?)?
> Querying tiles for altitudes at lat/lon pairs.
> Do you measure itme of only query only or query and
> raster blob
> processing/rendering?
> Time is for query only.
> What's your actual SQL command?
> This query is run for 10000 lat/lon pairs -
> ST_Transform(ST_SetSRID(ST_Point( lon,lat), 4326),
> ST_SRID(rast))) from srtm3 where filename='filename'
> ST_Transform(ST_SetSRID(ST_Point(lat,lon),
> Best regards,
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111102/f0774ff8/attachment.html>
