[postgis-users] Slow Query Times for Split Tiles
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Nov 3 13:32:16 PDT 2011
> Thanks for the suggestion. From the output, it doesn't look like it is using the
> index even though an index was created with the raster2pgsql.py script. Is there
> a specific way to tell the query to use the index?
Could you make sure you really created an index on the 50x50 pixel table. I don't see the -I option in your raster2pgsql.py command...
Pierre
