[postgis-users] PostGIS Conceptual and Phisical Modelling
Phil James
borntopedal at yahoo.co.uk
Thu Nov 3 06:00:31 PDT 2011
A simple way to see data in Quantum whilst running queries in Postgis is to write and test the query in Postgis then wrap it in a view. eg.
SELECT DISTINCT a.* FROM table1 a, table2 b WHERE ST_INTERSECTS(a.the_geom, b.the_geom)
can be written as
CREATE VIEW myview AS (SELECT DISTINCT a.* FROM table1 a, table2 b WHERE ST_INTERSECTS(a.the_geom, b.the_geom))
Provided there is a a field in the view that can be used as a key (the GID is a good one) then Quantum will display it.
If there is not a unique key (eg. if you use intersects and get multiple gids then you can use CREATE TABLE and then add a Primary Key and populate geometry columns eg:
CREATE TABLE mytable AS (SELECT a.* FROM table1 a, table2 b WHERE ST_INTERSECTS(a.the_geom, b.the_geom))
ALTER
TABLE mytable
ADD
COLUMN id SERIAL PRIMARY KEY;
SELECT POPULATE_GEOMETRY_COLUMNS('public.mytable'::regclass);
Then it will be visible from Quantum.
Hope this helps
Phil
>________________________________
>From: Carlos Andrade <carlosviansi at gmail.com>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Sent: Thursday, 3 November 2011, 8:03
>Subject: Re: [postgis-users] PostGIS Conceptual and Phisical Modelling
>Hi,
>Thank you everyone for all your suggestions! I'm gonna check on them! =)
>Paolo, I'm happy someone will find use of it, where should I put it?
>Carlos Andrade
>http://carlosandrade.co
>2011/11/3 Paolo Cavallini <cavallini at faunalia.it>
>Il 02/11/2011 18:55, Carlos Andrade ha scritto:
>>> I've created a small tutorial on how I got things wokrking around to set up on a snow
>>> leopard it, is this of any interest to this comunity? It may have information that it
>>> not 100% accurate, but it was what made it work on my mac. If yes, please let me know
>>> where could I put it (maybe the wiki, or where would it be).
>>Yes, please.
>>All the best.
>>Paolo Cavallini - Faunalia
>>www.faunalia.eu
>>Full contact details at www.faunalia.eu/pc
>>_______________________________________________
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111103/e38695d5/attachment.html>
