[postgis-users] PostGIS Conceptual and Phisical Modelling
Carlos Andrade
carlosviansi at gmail.com
Thu Nov 3 08:25:46 PDT 2011
Works great, I can see the views as long as I have a geometry on it, I just
need to work my current sql to keep moving the shape foward along with the
selected route now.
Thank you very much!! :-)
Carlos Andrade
http://carlosandrade.co
2011/11/3 Carlos Andrade <carlosviansi at gmail.com>
> Perfect!! Exactly what I needed. Now Im not constrained to the sql
> available on any of the GIS tools.
> I believe Quantum will notice it when I connect to my database and request
> to load the data inside my geo database?
> I'll give it a shot!
> Thank you very much! Hopefully I'll figure it out before the pres today :D
> Carlos Andrade
> 2011/11/3 Phil James <borntopedal at yahoo.co.uk>
>> A simple way to see data in Quantum whilst running queries in Postgis is
>> to write and test the query in Postgis then wrap it in a view. eg.
>> SELECT DISTINCT a.* FROM table1 a, table2 b WHERE
>> ST_INTERSECTS(a.the_geom, b.the_geom)
>> can be written as
>> CREATE VIEW myview AS (SELECT DISTINCT a.* FROM table1 a, table2 b WHERE
>> ST_INTERSECTS(a.the_geom, b.the_geom))
>> Provided there is a a field in the view that can be used as a key (the
>> GID is a good one) then Quantum will display it.
>> If there is not a unique key (eg. if you use intersects and get multiple
>> gids then you can use CREATE TABLE and then add a Primary Key and populate
>> geometry columns eg:
>> CREATE TABLE mytable AS (SELECT a.* FROM table1 a, table2 b WHERE
>> ALTER TABLE mytable
>> ADD COLUMN id SERIAL PRIMARY KEY;
>> SELECT POPULATE_GEOMETRY_COLUMNS('public.mytable'::regclass);
>> Then it will be visible from Quantum.
>> Hope this helps
>> Phil
>> *From:* Carlos Andrade <carlosviansi at gmail.com>
>> *To:* PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>> *Sent:* Thursday, 3 November 2011, 8:03
>> *Subject:* Re: [postgis-users] PostGIS Conceptual and Phisical Modelling
>> Hi,
>> Thank you everyone for all your suggestions! I'm gonna check on them! =)
>> Paolo, I'm happy someone will find use of it, where should I put it?
>> Carlos Andrade
>> 2011/11/3 Paolo Cavallini <cavallini at faunalia.it>
>> Il 02/11/2011 18:55, Carlos Andrade ha scritto:
>> > I've created a small tutorial on how I got things wokrking around to
>> set up on a snow
>> > leopard it, is this of any interest to this comunity? It may have
>> information that it
>> > not 100% accurate, but it was what made it work on my mac. If yes,
>> please let me know
>> > where could I put it (maybe the wiki, or where would it be).
>> Yes, please.
>> All the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111103/ad90762c/attachment.html>
