[postgis-users] ERROR: Operation on two geometries with different SRIDs
Stefan Schwarzer
stefan.schwarzer at unep.org
Mon Nov 7 06:07:24 PST 2011
Hi there,
I am somewhat fighting with the projection of my file.
I have a file for Morocco, which, after ArcMap, has the following projection:
Projected Coordinate System: zone1
Projection: Lambert_Conformal_Conic
False_Easting: 500000.00000000
False_Northing: 300000.00000000
Central_Meridian: -5.40000000
Standard_Parallel_1: 34.86600000
Standard_Parallel_2: 31.72500000
Scale_Factor: 1.00000000
Latitude_Of_Origin: 33.30000000
Linear Unit: Meter
Geographic Coordinate System: GCS_Merchich_Degree
Datum: D_Merchich
After looking around, it seems to be the EPSG 26191 (http://spatialreference.org/ref/epsg/26191/).
Now, trying to import it with:
shp2pgsql -s EPSG:26191 -I -D morocco.shp morocco > morocco.sql
psql -U xxxx my_database < morocco.sql
I can see in the SQL file that the SRID is set to -1. If I change this to 26191, and try to import it then, it gives me an error message:
ERROR: new row for relation "morocco" violates check constraint "enforce_srid_the_geom"
So, I changed the SRID in the geometry_columns manually.
But when trying to map the layer, I receive the error messsage:
My Mapserver.map file show only SQLs with 26191, for projection of main document, as well as SQLs such as:
DATA 'the_geom FROM morocco USING UNIQUE gid USING srid=26191'
Extent and units of the mapserver file have been changed to the proper extent/units.
So, I am confused about where the problem comes from. It would be great if someone could give me a hint where the error lies.
Thanks a lot!
