[postgis-users] Problem after reprojecting: Extent: BOX(inf inf, inf inf)
Jan Peters
petersjan at gmx.at
Mon Nov 7 09:47:45 PST 2011
Sorry for posting in a reply last time:
Dear all,
I am a bit stuck: I just encountered that some of my PostGIS datasets were defined as EPSG:31259 in the geometry_colums table, but the geometry data was actually EPSG:4326. Now I wanted to project this data from 4326 to 31259 via:
CREATE TABLE table_31259 AS
SELECT
table_4326.id,
ST_Transform(the_geom,31259) AS the_geom
FROM table_4326;
which had already been working for other tables, but the newest tables seem to resist correct projection because when I run
select ST_extent(table_4326.the_geom)
FROM table_4326;
I get:
st_extent:
BOX(4130129.75 -3197344.75,4439015 -2797768.25) /*which is correct*/
after projecting the data to EPSG:31259 I get:
st_extent:
BOX(inf inf,inf inf) /*which means there is obviously something wrong*/
Do I miss something here? I also tried to update the SRID in table_4326 like:
SELECT updategeometrysrid('table_4326', 'the_geom', 4326);
and then:
SELECT setsrid(the_geom, 4326) from table_4326;
and after that projecting the data to EPSG:31259 again, so there must be something going fundamentally wrong I fear.
Thanks for any replies
Jan
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
