[postgis-users] Updating Geometry
Sandro Santilli
strk at keybit.net
Thu Nov 10 22:24:10 PST 2011
On Thu, Nov 10, 2011 at 01:55:57PM -0800, Asli Akarsakarya wrote:
> I am having trouble when attempting to update an existing geometry on a spatial table. The table stores 2D Point geometry, with the SRID 101. The update statement i am trying to use to update the geometry with the id 110 is as follows:
> UPDATE <Table_Name> SET <Geometry_Column_Name> = GeometryFromText('POINT(44 31)', 101) WHERE <id_Column>=110
> But I get an error that says the statement violates the "enforce_srid_position" restriction. Though the SRID's are the same.
Probably they aren't. Try:
UPDATE <Table_Name> SET <Geometry_Coumn_Name> = GeometryFromText(
'POINT(44 31)', ST_Srid(<Geometry_Column_Name>)) WHERE <id_Column>=110;
Then check what "enforce_srid_position" is
(doesn't sound like the correct name) using:
\d <Table_Name>
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
