[postgis-users] Updating Geometry
Asli Akarsakarya
asliakar at yahoo.com
Fri Nov 11 01:15:28 PST 2011
Thank you Sandro,
The way you suggested works fine.
Though, I wonder what I cannot see. In the geometry_columns table, when I check the geometry's SRID, it is coded as 101. And this, I give to the "GeometryFromText" function. The only thing possible is, there's another coded srid in the geometry; which doesnt match the SRID in geometry_columns table. Any other suggestions?
"enforce_srid_<Geometry_Column_Name>" is a restriction defined on the spatial table. ("position" is the name of my column, sorry.)
Thanks again.
To: Asli Akarsakarya <asliakar at yahoo.com>; PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Friday, November 11, 2011 8:24 AM
Subject: Re: [postgis-users] Updating Geometry
On Thu, Nov 10, 2011 at 01:55:57PM -0800, Asli Akarsakarya wrote:
> I am having trouble when attempting to update an existing geometry on a spatial table. The table stores 2D Point geometry, with the SRID 101. The update statement i am trying to use to update the geometry with the id 110 is as follows:
> UPDATE <Table_Name> SET <Geometry_Column_Name> = GeometryFromText('POINT(44 31)', 101) WHERE <id_Column>=110
> But I get an error that says the statement violates the "enforce_srid_position" restriction. Though the SRID's are the same.
Probably they aren't. Try:
UPDATE <Table_Name> SET <Geometry_Coumn_Name> = GeometryFromText(
'POINT(44 31)', ST_Srid(<Geometry_Column_Name>)) WHERE <id_Column>=110;
Then check what "enforce_srid_position" is
(doesn't sound like the correct name) using:
\d <Table_Name>
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111111/ceeeb51b/attachment.html>
