[postgis-users] Workaround for "transform: couldn't project point"	error?
    Evan Martin
    postgresql at realityexists.net
    Thu Nov 17 19:19:31 PST 2011
I'm importing some data into a PostGIS DB. The points in the data come
in various SRIDs, but I need to transform them all to 4326 to use the
geography type.
A simple ST_Transform() doesn't always work for this, because of the
error in http://trac.osgeo.org/postgis/ticket/318 So I tried
transforming via 3395, eg.
SELECT
ST_AsText(ST_Transform(ST_Transform(ST_GeomFromEWKT('SRID=4267;POINT(-31.94944
52.38833)'), 3395), 4326))
This works for most points, but fails at the poles, eg.
SELECT
ST_AsText(ST_Transform(ST_Transform(ST_GeomFromEWKT('SRID=4267;POINT(-80
-90)'), 3395), 4326))
     ERROR:  transform: couldn't project point (-80 -90 0): tolerance
condition error (-20)
Is there any effective workaround for this? Is the bug likely to be
fixed any time soon? It's been open for some time and a few people have
run into it.
Regards,
Evan
