[postgis-users] ST_ShortestLine(r.geom, m.geom) confusion - better limiting point to nearest line results
Chris English
sglish at hotmail.com
Tue Nov 22 07:36:49 PST 2011
create table summit_final_drop_8 asselect Distinct ST_ShortestLine(a.intersection_geom, b.geom) from summit_parcels_centroid as b, summit_roads as a where ST_DWithin(a.intersection_geom,b.geom,150) ;
This got me nearly there and preserves the start/end of the line segment needed for_pg_routing, though throws up additional or excess final connections, probablya limit would help. At least as viewed in UDig, the segment lengths looked right . I'll look into nearest neighbor as an alternative solution.
Date: Tue, 22 Nov 2011 06:19:48 +0000
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] ST_ShortestLine(r.geom, m.geom) confusion - better limiting point to nearest line results
Yes you will as it finds the shortest distance each time between points and lines, sorry - you need the inner query to give you the nearest neighbour and then generate the line between that and the point. Have a quick search for "nearest neighbour postgis" for how to do this. That should give you the results you are after.
I think I have something somewhere if you can't find it online.
Phil
Fromris English <sglish at hotmail.com>
To: postgis_users <postgis-users at postgis.refractions.net>
Sent: Tuesday, 22 November 2011, 1:09
Thanks Phil for your response. The below does greatly reduce number of rows created through theinner join.The "shortestlines' unfortunately seem to radiate from the center of town.
create table summit_final_drop asselect ST_ShortestLine(nearestgeom.intersection_geom, b.geom) from summit_parcels_centroid as b, (Select a.*,
ST_Distance(a.intersection_geom, b.geom) as dist from summit_roads as a, summit_parcels_centroid as b order by dist asc limit 1) as nearestgeom;Query returned successfully with no result in 12281 ms.
Changing asc limit 1) to desc limit 1) and all segments come from the edge of as if a fan.
I return to your suggested order ST_Shortestline(point, line) - though I was concerned that this will flip my start/end points for the segment with an eyetoward the final part, pg_routing
create table summit_final_drop_4 asselect ST_ShortestLine(b.geom, nearestgeom.geom) from summit_parcels_centroid as b, (Select a.*,
And result is same radiation from the center.
Running St_ShortestLine twice:
create table summit_final_drop_7 asselect ST_ShortestLine(nearestgeom.geom, b.geom) from summit_parcels_centroid as b, (Select
a.*,
ST_Shortestline(a.intersection_geom, b.geom) as dist from summit_roads as a, summit_parcels_centroid as b order by dist asc limit 1 ) as nearestgeom;
Fan again. So, something about the order that roads are compared to points. I'll keep poking around.Chris
Date: Mon, 21 Nov 2011 22:13:33 +0000
Subject: Re:
[postgis-users] ST_ShortestLine(r.geom, m.geom) confusion - limiting point to nearest line results
To: postgis-users at postgis.refractions.net; sglish at hotmail.com
Hi Chris
You need an inner query that selects the closest line segment and use that geometry in the shortest line query
Select shrtest line(p.the_geom,nearestgeom.thegeom) from
Points p,
Select a.*, st_distance(a.the_geom, b.the_geom) as dist from roads a,points b order by dist asc limit 1) as nearestgeom
Hope this is readable as sending from phone.
Chris English <sglish at hotmail.com>;
To:
<postgis-users at postgis.refractions.net>;
Subject:
Sent:
Mon, Nov 21, 2011 9:00:47 PM
Hi all,
My goal is to model electric distribution in a municipality with 8.4, PostGis 1.5 and pgrouting.
I clipped roads and parcels from state level (roads) and county level (parcels) to get roads and parcels fora municipality resulting in two tables:
summit_roads (306 rows) and summit_parcels (6874 rows) . The roads table generally conforms to the layout of electric distribution.I then extracted a centroids table from parcels to try to develop the 'final drop' line segment, the last bit of wire fromdistribution wire (roads) to a home or business with the final goal to then join to final drop to roads for end to end distribution.
explain create table summit_final_drop asselect Distinct ST_ShortestLine(r.intersection_geom, m.geom) as
final_drop_geom,r.sld_name,r.measured_l,m.pams_pin,m.mun,m.block,m.lot,m.qcodefrom summit_roads as r,summit_parcels_centroid as m;
This code resulted in 2,109,000 rows , essentially centroid to every line point as against whatI was expecting.
Suggestions appreciated.
Thanks,Chris
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111122/fcf2b040/attachment.html>
