[postgis-users] Typmod and triggers
Paragon Corporation
lr at pcorp.us
Tue Nov 22 17:43:00 PST 2011
Jose,
slight omission in my last
> -- to put back constraints on it --
> SELECT populate_geometry_columns('a'::regclass);
I forgot that use type mod is the default now -- so the above should be
SELECT populate_geometry_columns('a'::regclass, false);
To force it to constrain the geometry using constraints instead of typmod.
Hope that helps,
Regina
http://www.postgis.us
