[postgis-users] Raster pixel value
Tom van Tilburg
tom.van.tilburg at gmail.com
Thu Nov 24 02:39:15 PST 2011
Andreas,
We did approx. the same thing for non-quadrate polygons. Perhaps it
might be useful:
Step 1: Make a raster from every polygon, based on the grid
specifications of the elevation raster. Here is also the solution: the
raster cells will only be created for cells that have their midpoint
*inside* your geometry.
ST_AsRaster(a.geom, b.rast, '<pixtype>')
Step 2: Overlay the elevation raster with the raster you just created
and keep only the values of the elevation raster
ST_MapAlgebraExpr(
<raster from geometry>
,b.rast
,'rast2' -- <-- keep only raster 2 value
, '<pixtype>','INTERSECTION','0','0',0
Step 3: get the mean from the statistics on the resulting raster
(ST_SummaryStats(
(ST_Union( -- < --- we did a UNION because we occasionaly had
vectors crossing tiled rasters
<overlay raster>
)).rast
)).mean As avg_height
That did the trick. Complete script is below.
I suspect your method of doing a ST_Intersection for every pix. makes it
slower because it creates a geometry first that you do not really need.
Cheers,
Tom
FULL SCRIPT
SELECT
a.gid As id,
(ST_SummaryStats(
(ST_Union(
ST_MapAlgebraExpr(
ST_AsRaster(a.geom, b.rast, '32BF')
,b.rast
,'rast2', '32BF','INTERSECTION','0','0',0
)).rast
FROM
polygons.grid a LEFT JOIN
rasters.elev b
ON ST_Intersects(a.geom, b.rast)
GROUP BY a.gid
On 24-11-2011 11:14, Andreas Forø Tollefsen wrote:
> Hi,
> I am trying to calculate the average pixel value in a elevation raster
> inside quadrate polygons.
> However, I am not getting the correct values from my query:
> SELECT gid, AVG(((foo.geomval).val)) as avgmnt
> FROM (SELECT p.gid, ST_Intersection(p.cell, r.rast) AS geomval FROM
> mountain r, priogrid_land p WHERE ST_Intersects(p.cell, r.rast, ) AND
> p.gid =186124) AS foo
> GROUP BY gid ORDER BY gid;
> The problem here is that the ST_Intersects(geom, rast) takes into
> consideration the pixels that is outside, but touches the border of
> the quadrate polygons. Then, the average values for each quadrate
> polygon is affected by pixels inside other polygons. This will
> potentially lead to a flawed result.
> So what I want is to be able to calculate the average value for the
> pixels INSIDE the polygon excluding those outside.
> How can i restrict the AVG pixel value to be calculated only for
> pixels that is inside the polygon, and not the pixels that touch the
> outside of the border?
> Thanks!
> Best,
> Andreas
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111124/77eeb013/attachment.html>
