[postgis-users] Raster pixel value
Andreas Forø Tollefsen
andreasft at gmail.com
Thu Nov 24 03:07:48 PST 2011
Great, Thank you so much for this.
However, I do not seem to have the ST_MapAlgebraExpr(rast, rast.....)
function. Was this implemented in rev 8001?
Andreas
2011/11/24 Tom van Tilburg <tom.van.tilburg at gmail.com>
> Andreas,
> We did approx. the same thing for non-quadrate polygons. Perhaps it might
> be useful:
> Step 1: Make a raster from every polygon, based on the grid specifications
> of the elevation raster. Here is also the solution: the raster cells will
> only be created for cells that have their midpoint *inside* your geometry.
> ST_AsRaster(a.geom, b.rast, '<pixtype>')
> Step 2: Overlay the elevation raster with the raster you just created and
> keep only the values of the elevation raster
> ST_MapAlgebraExpr(
> <raster from geometry>
> ,b.rast
> ,'rast2' -- <-- keep only raster 2 value
> , '<pixtype>','INTERSECTION','0','0',0
> Step 3: get the mean from the statistics on the resulting raster
> (ST_SummaryStats(
> (ST_Union( -- < --- we did a UNION because we occasionaly had vectors
> crossing tiled rasters
> <overlay raster>
> )).rast
> )).mean As avg_height
> That did the trick. Complete script is below.
> I suspect your method of doing a ST_Intersection for every pix. makes it
> slower because it creates a geometry first that you do not really need.
> Cheers,
> Tom
> FULL SCRIPT
> SELECT
> a.gid As id,
> (ST_SummaryStats(
> (ST_Union(
> ST_MapAlgebraExpr(
> ST_AsRaster(a.geom, b.rast, '32BF')
> ,b.rast
> ,'rast2', '32BF','INTERSECTION','0','0',0
> )).rast
> FROM
> polygons.grid a LEFT JOIN
> rasters.elev b
> ON ST_Intersects(a.geom, b.rast)
> GROUP BY a.gid
> On 24-11-2011 11:14, Andreas Forø Tollefsen wrote:
> Hi,
> I am trying to calculate the average pixel value in a elevation raster
> inside quadrate polygons.
> However, I am not getting the correct values from my query:
> SELECT gid, AVG(((foo.geomval).val)) as avgmnt
> FROM (SELECT p.gid, ST_Intersection(p.cell, r.rast) AS geomval FROM
> mountain r, priogrid_land p WHERE ST_Intersects(p.cell, r.rast, ) AND p.gid
> =186124) AS foo
> GROUP BY gid ORDER BY gid;
> The problem here is that the ST_Intersects(geom, rast) takes into
> consideration the pixels that is outside, but touches the border of the
> quadrate polygons. Then, the average values for each quadrate polygon is
> affected by pixels inside other polygons. This will potentially lead to a
> flawed result.
> So what I want is to be able to calculate the average value for the pixels
> INSIDE the polygon excluding those outside.
> How can i restrict the AVG pixel value to be calculated only for pixels
> that is inside the polygon, and not the pixels that touch the outside of
> the border?
> Thanks!
> Best,
> Andreas
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111124/fd105784/attachment.html>
