[postgis-users] Geocoding cross streets?
Paragon Corporation
lr at pcorp.us
Mon Nov 28 14:53:52 PST 2011
Steve,
Yap that's what we were thinking. That's why we have it as a separate
function specifically for cross intersection which will take the form:
geocode_intersection(roadway1, roadway2, city, state, zip)
So we at least for the first pass, are not going to assume any symbol etc.
to break (we have enough issues with our normalize logic that we are
cleaning up).
We'll force people to type the streets in as separate arguments.
For our case we already have it coded that way so the easiest to port since
ours (the use case we have it coded for) is fed from a user interface
that looks somethng like
where people have
Address: ________________________________ (goes regular route)
or
Cross Street of ______________ and _____________ (goes thru our geocode
intersection route)
option.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: Monday, November 28, 2011 5:39 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Geocoding cross streets?
> On 11/28/2011 5:28 PM, Aren Cambre wrote:
> > I think that *geocode_intersection* function would be perfect!
> > I just entered an enhancement request at
> > http://trac.osgeo.org/postgis/ticket/1333.
> > I totally understand about merging into the existing
> *geocode* function.
> > A counter-strategy might be to require the *&* symbol? But if you're
> This is actually not a good idea from the point of view that
> the Tiger data does have street names the contain an &
> character like "B & O", "Tom & Ann" or something like that,
> and others. I already did this analysis when looking at PAGC
> geocoder and Tiger data. You will also fine the word "and" in
> some street names so that is not good as a separator. In PAGC
> I arbitrarily pick the '@' character as it is not used in the
> Tiger data and it reads as "street a (at) street b" which
> seems as good as any definition for an intersection.
> Thanks,
> -Steve W
> > requiring that, then seems like it wouldn't be much more
> work for the
> > developer to split into cross streets rather than having postgis
> > figure that out upon every geocode.
> > Aren
> > On Mon, Nov 28, 2011 at 4:08 PM, Paragon Corporation <lr at pcorp.us
> > <mailto:lr at pcorp.us>> wrote:
> > It doesn't geocode cross streets or if it is its share
> accident. I
> > think what it's doing is just picking the first one
> most likely so
> > you are getting at the beginning of a street with that
> name and it's
> > ignoring the second street at best.
> > The cross streets feature takes a different algorithm.
> We do have
> > that coded as a sub process in one of our projects, but it's not
> > committed in tiger geocoder. Feel free to post a ticket under
> > tiger_geocoder
> > if you are interested in seeing it incorporated into
> tiger geocoder.
> > Right now what we have can be relatively easily incorporated in
> > tiger geocoder to be a function of the form:
> > Would that work for you? I would hesitate to try to
> merge into the
> > existing geocode function since I'm not sure how much
> unnecessary
> > processing that would add if people know they aren't
> dealing with
> > cross street addresses.
> > Thanks,
> > Leo and Regina
> > http://www.postgis.us
> > *From:* postgis-users-bounces at postgis.refractions.net
> > <mailto:postgis-users-bounces at postgis.refractions.net>
> > <mailto:postgis-users-bounces at postgis.refractions.net>] *On
> > Behalf Of *Aren Cambre
> > *Sent:* Monday, November 28, 2011 3:14 PM
> > *To:* PostGIS Users Discussion
> > *Subject:* Re: [postgis-users] Geocoding cross streets?
> > Hey, thanks!
> > I used this query:
> > *SELECT g.rating, ST_X(geomout) AS lon,
> ST_Y(geomout) AS lat,
> > (addy).* FROM geocode('XXXX') as g;*
> > where *XXXX* is replaced with strings like:
> > * *erin and tralee, dallas, tx*
> > * *erin & tralee, dallas, tx*
> > * *sagecanyon & sagegreen, houston, tx*
> > Those produce lat/longs that are a few miles from
> the correct
> > locations.
> > Aren
> > On Mon, Nov 28, 2011 at 1:33 PM, Johnathan Leppert
> > <johnathan.leppert at gmail.com
> > <mailto:johnathan.leppert at gmail.com>> wrote:
> > Cross-streets should be supported. Can you
> supply your exact
> > query and what versions of PostGIS and geocoder
> you are using?
> > Johnathan
> > On Mon, Nov 28, 2011 at 9:26 AM, Aren Cambre
> > <aren at arencambre.com
> <mailto:aren at arencambre.com>> wrote:
> > I have the TIGER geocoder running with
> PostGIS 2.0 as
> > per
> http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
> > It seems to do well finding street addresses, but it
> > can't seem to find cross streets. For example, if I
> > geocode *sagecanyon and sagegreen, houston,
> tx*, I get a
> > location on the other side of town. Here's
> a Google Map
> > showing both: http://g.co/maps/nphp9
> > Can I even use the TIGER geocoder for cross streets?
> > Aren
> > postgis-users mailing list
> > <mailto:postgis-users at postgis.refractions.net>
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > /Johnathan /
> > Software Engineer
> > San Francisco, California
> > /Follow me on Twitter: @iamleppert
> > <http://twitter.com/#!/iamleppert> /
