[postgis-users] Geocoding cross streets?
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 28 14:39:10 PST 2011
On 11/28/2011 5:28 PM, Aren Cambre wrote:
> I think that *geocode_intersection* function would be perfect!
> I just entered an enhancement request at
> http://trac.osgeo.org/postgis/ticket/1333.
> I totally understand about merging into the existing *geocode* function.
> A counter-strategy might be to require the *&* symbol? But if you're
This is actually not a good idea from the point of view that the Tiger
data does have street names the contain an & character like "B & O",
"Tom & Ann" or something like that, and others. I already did this
analysis when looking at PAGC geocoder and Tiger data. You will also
fine the word "and" in some street names so that is not good as a
separator. In PAGC I arbitrarily pick the '@' character as it is not
used in the Tiger data and it reads as "street a (at) street b" which
seems as good as any definition for an intersection.
Thanks,
-Steve W
> requiring that, then seems like it wouldn't be much more work for the
> developer to split into cross streets rather than having postgis figure
> that out upon every geocode.
> Aren
> On Mon, Nov 28, 2011 at 4:08 PM, Paragon Corporation <lr at pcorp.us
> <mailto:lr at pcorp.us>> wrote:
> It doesn't geocode cross streets or if it is its share accident. I
> think what it's doing is just picking the first one most likely so
> you are getting at the beginning of a street with that name and it's
> ignoring the second street at best.
> The cross streets feature takes a different algorithm. We do have
> that coded as a sub process in one of our projects, but it's not
> committed in tiger geocoder. Feel free to post a ticket under
> tiger_geocoder
> if you are interested in seeing it incorporated into tiger geocoder.
> Right now what we have can be relatively easily incorporated in
> tiger geocoder to be a function of the form:
> geocode_intersection(roadway1, roadway2, city, state, zip)
> Would that work for you? I would hesitate to try to merge into the
> existing geocode function since I'm not sure how much unnecessary
> processing that would add if people know they aren't dealing with
> cross street addresses.
> Thanks,
> Leo and Regina
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>
> [mailto:postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>] *On
> Behalf Of *Aren Cambre
> *Sent:* Monday, November 28, 2011 3:14 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Geocoding cross streets?
> Hey, thanks!
> I used this query:
> *SELECT g.rating, ST_X(geomout) AS lon, ST_Y(geomout) AS lat,
> (addy).* FROM geocode('XXXX') as g;*
> where *XXXX* is replaced with strings like:
> * *erin and tralee, dallas, tx*
> * *erin & tralee, dallas, tx*
> * *sagecanyon & sagegreen, houston, tx*
> Those produce lat/longs that are a few miles from the correct
> locations.
> Aren
> On Mon, Nov 28, 2011 at 1:33 PM, Johnathan Leppert
> <johnathan.leppert at gmail.com
> <mailto:johnathan.leppert at gmail.com>> wrote:
> Cross-streets should be supported. Can you supply your exact
> query and what versions of PostGIS and geocoder you are using?
> Johnathan
> On Mon, Nov 28, 2011 at 9:26 AM, Aren Cambre
> <aren at arencambre.com <mailto:aren at arencambre.com>> wrote:
> I have the TIGER geocoder running with PostGIS 2.0 as
> per
> http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
> It seems to do well finding street addresses, but it
> can't seem to find cross streets. For example, if I
> geocode *sagecanyon and sagegreen, houston, tx*, I get a
> location on the other side of town. Here's a Google Map
> showing both: http://g.co/maps/nphp9
> Can I even use the TIGER geocoder for cross streets?
> Aren
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
> /Johnathan /
> Software Engineer
> San Francisco, California
> /Follow me on Twitter: @iamleppert
> <http://twitter.com/#!/iamleppert> /
