[postgis-users] Geocoding cross streets?
Aren Cambre
aren at arencambre.com
Mon Nov 28 19:41:52 PST 2011
Is there anything I can to do help this happen? I admit I haven't done much
intensively with C++ since my undergrad in the late '90s. I'm in the
coddled world of IT now and use stuff like C#. :-)
Aren
On Mon, Nov 28, 2011 at 5:30 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Yes, this makes sense. Regardless you can always add a higher level parser
> to deal with parsing a single field of input and splitting it into fields
> and then deciding which appropriate API to call to get results.
> I have written and contributed to PAGC a single line address parser that
> works for US addresses. It is a standalone C module that can be reused and
> is licensed under MIT-X style license, so it could be picked up and easily
> wrapped with a plpgsql wrapper to pass text on input and get a fielded
> record of parsed results.
> -Steve
> On 11/28/2011 5:53 PM, Paragon Corporation wrote:
>> Steve,
>> Yap that's what we were thinking. That's why we have it as a separate
>> function specifically for cross intersection which will take the form:
>> geocode_intersection(roadway1, roadway2, city, state, zip)
>> So we at least for the first pass, are not going to assume any symbol etc.
>> to break (we have enough issues with our normalize logic that we are
>> cleaning up).
>> We'll force people to type the streets in as separate arguments.
>> For our case we already have it coded that way so the easiest to port
>> since
>> ours (the use case we have it coded for) is fed from a user interface
>> that looks somethng like
>> where people have
>> Address: ______________________________**__ (goes regular route)
>> or
>> Cross Street of ______________ and _____________ (goes thru our geocode
>> intersection route)
>> option.
>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.**refractions.net<postgis-users-bounces at postgis.refractions.net>
>>> [mailto:postgis-users-bounces@**postgis.refractions.net<postgis-users-bounces at postgis.refractions.net>]
>>> On
>>> Behalf Of Stephen Woodbridge
>>> Sent: Monday, November 28, 2011 5:39 PM
>>> To: postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>> Subject: Re: [postgis-users] Geocoding cross streets?
>>> On 11/28/2011 5:28 PM, Aren Cambre wrote:
>>>> I think that *geocode_intersection* function would be perfect!
>>>> I just entered an enhancement request at
>>>> http://trac.osgeo.org/postgis/**ticket/1333<http://trac.osgeo.org/postgis/ticket/1333>
>>>> I totally understand about merging into the existing
>>> *geocode* function.
>>>> A counter-strategy might be to require the *&* symbol? But if you're
>>> This is actually not a good idea from the point of view that
>>> the Tiger data does have street names the contain an&
>>> character like "B& O", "Tom& Ann" or something like that,
>>> and others. I already did this analysis when looking at PAGC
>>> geocoder and Tiger data. You will also fine the word "and" in
>>> some street names so that is not good as a separator. In PAGC
>>> I arbitrarily pick the '@' character as it is not used in the
>>> Tiger data and it reads as "street a (at) street b" which
>>> seems as good as any definition for an intersection.
>>> Thanks,
>>> -Steve W
>>> requiring that, then seems like it wouldn't be much more
>>> work for the
>>>> developer to split into cross streets rather than having postgis
>>>> figure that out upon every geocode.
>>>> Aren
>>>> On Mon, Nov 28, 2011 at 4:08 PM, Paragon Corporation<lr at pcorp.us
>>>> <mailto:lr at pcorp.us>> wrote:
>>>> It doesn't geocode cross streets or if it is its share
>>> accident. I
>>>> think what it's doing is just picking the first one
>>> most likely so
>>>> you are getting at the beginning of a street with that
>>> name and it's
>>>> ignoring the second street at best.
>>>> The cross streets feature takes a different algorithm.
>>> We do have
>>>> that coded as a sub process in one of our projects, but it's not
>>>> committed in tiger geocoder. Feel free to post a ticket under
>>>> tiger_geocoder
>>>> if you are interested in seeing it incorporated into
>>> tiger geocoder.
>>>> Right now what we have can be relatively easily incorporated in
>>>> tiger geocoder to be a function of the form:
>>>> Would that work for you? I would hesitate to try to
>>> merge into the
>>>> existing geocode function since I'm not sure how much
>>> unnecessary
>>>> processing that would add if people know they aren't
>>> dealing with
>>>> cross street addresses.
>>>> Thanks,
>>>> Leo and Regina
>>>> http://www.postgis.us
>>>> *From:* postgis-users-bounces at postgis.**refractions.net<postgis-users-bounces at postgis.refractions.net>
>>>> <mailto:postgis-users-bounces@**postgis.refractions.net<postgis-users-bounces at postgis.refractions.net>
>>>> <mailto:postgis-users-bounces@**postgis.refractions.net<postgis-users-bounces at postgis.refractions.net>>]
>>>> *On
>>>> Behalf Of *Aren Cambre
>>>> *Sent:* Monday, November 28, 2011 3:14 PM
>>>> *To:* PostGIS Users Discussion
>>>> *Subject:* Re: [postgis-users] Geocoding cross streets?
>>>> Hey, thanks!
>>>> I used this query:
>>>> *SELECT g.rating, ST_X(geomout) AS lon,
>>> ST_Y(geomout) AS lat,
>>>> (addy).* FROM geocode('XXXX') as g;*
>>>> where *XXXX* is replaced with strings like:
>>>> * *erin and tralee, dallas, tx*
>>>> * *erin& tralee, dallas, tx*
>>>> * *sagecanyon& sagegreen, houston, tx*
>>>> Those produce lat/longs that are a few miles from
>>> the correct
>>>> locations.
>>>> Aren
>>>> On Mon, Nov 28, 2011 at 1:33 PM, Johnathan Leppert
>>>> <johnathan.leppert at gmail.com
>>>> <mailto:johnathan.leppert@**gmail.com<johnathan.leppert at gmail.com>>>
>>>> wrote:
>>>> Cross-streets should be supported. Can you
>>> supply your exact
>>>> query and what versions of PostGIS and geocoder
>>> you are using?
>>>> Johnathan
>>>> On Mon, Nov 28, 2011 at 9:26 AM, Aren Cambre
>>>> <aren at arencambre.com
>>> <mailto:aren at arencambre.com>> wrote:
>>>> I have the TIGER geocoder running with
>>> PostGIS 2.0 as
>>>> per
>>>> http://www.letseehere.com/**postgis-geocoder-using-tiger-**2010-data<http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data>
>>>> It seems to do well finding street addresses, but it
>>>> can't seem to find cross streets. For example, if I
>>>> geocode *sagecanyon and sagegreen, houston,
>>> tx*, I get a
>>>> location on the other side of town. Here's
>>> a Google Map
>>>> showing both: http://g.co/maps/nphp9
>>>> Can I even use the TIGER geocoder for cross streets?
>>>> Aren
>>>> ______________________________**_________________
>>>> postgis-users mailing list
>>>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>> /Johnathan /
>>>> Software Engineer
>>>> San Francisco, California
>>>> /Follow me on Twitter: @iamleppert
>>>> <http://twitter.com/#!/**iamleppert<http://twitter.com/#!/iamleppert>>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111128/2f6af218/attachment.html>
