[postgis-users] PostGIS Topology pledge: 2 people have signed up, 8 more needed
Sandro Santilli strk at keybit.net
Mon Nov 28 23:17:24 PST 2011
This is just a reminder about the fundraising drive aimed at improving
the PostGIS topology support in upcoming 2.0 release.
<< I will implement a Geometry to TopoGeometry importer in
   PostGIS-2.0 but only if 10 other people will donate 250 euro. >>
      http://www.pledgebank.com/postgistopology
The idea is that such a new function would make it extremely simple
for you to start using topology for your layers. As simple as:
  UPDATE layer SET topo_geom = toTopoGeometry('layertopo', geom);
You could use the topological representation just to cleanup the data [1],
to produce a pyramid of simplified versions or simply for storage and
exchange with other systems (topological GML output already available).
[1] http://strk.keybit.net/blog/2011/11/21/topology-cleaning-with-postgis/
As of today 2 people have signed (thank you Andreas!, thank you Brian!).
It will take 8 more signatures to get it started.
The pledge deadline is December 20th.
Go postgis community, go !
--strk;
  ()   Free GIS consultant/developer
  /\   http://strk.keybit.net/
