[postgis-users] bmd.hasnodata does not exist
Bborie Park
bkpark at ucdavis.edu
Wed Nov 30 09:10:45 PST 2011
Andreas,
Though you upgraded the underlying library, did you run
rtpostgis_upgrade_20_minor.sql? Something is definitely out of sync.
-bborie
On Tue, Nov 29, 2011 at 12:58 AM, Andreas Forø Tollefsen
<andreasft at gmail.com> wrote:
> No one else had the same issue with 8242? This is exactly the same query as
> i ran in r.8001, but now it give me the error below in return.
> Any suggestions?
> Best,
> Andreas
> 2011/11/25 Andreas Forø Tollefsen <andreasft at gmail.com>
>> Hi,
>> Sorry for posting a lot these days but I am very busy finalizing a
>> project.
>> Previously, I have been running the following query without problems (in
>> rev.8001). After updating to rev.8242 i am getting a strange error.
>> Could someone please see what is wrong? Is it one of the functions that
>> has changed?
>> Query:
>> SELECT gid, AVG(((foo.geomval).val)) FROM (SELECT p.gid,
>> ST_Intersection(p.cell, r.rast) AS geomval FROM mountain r, priogrid_land p
>> WHERE ST_Intersects(p.cell, r.rast) AND p.gid =219260) AS foo
>> GROUP BY gid ORDER BY gid;
>> Error:
>> ERROR: column bmd.hasnodata does not exist
>> LINE 1: SELECT bmd.hasnodata FROM ST_BandMetaData(ras...
>> QUERY: SELECT bmd.hasnodata FROM ST_BandMetaData(rast,
>> nband) AS bmd
>> CONTEXT: PL/pgSQL function "_st_intersects" line 32 at SQL statement
>> PL/pgSQL function "st_intersection" line 5 at assignment
>> ********** Error **********
>> SQL state: 42703
>> Context: PL/pgSQL function "_st_intersects" line 32 at SQL statement
>> Thanks for any help.
>> Best regards,
>> Andreas
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
