[postgis-users] Error on updating geometry column from two columns value
Firman Hadi jalmiburung at gmail.com
Wed Nov 30 23:31:26 PST 2011
Dear all,
I want to create one table with 3 columns (x, y, geom). I want to input
the x and y using form with PHP.
When I submit the form, it will trigger the new row.
I use this step below but when I insert the data I get the error as in
attachment.
I hope that anyone can help me to solve the problem.
Thank you in advance.
Kind regards,
Firman Hadi
Center for Remote Sensing - ITB
Indonesia
CREATE TABLE try_geometry (
      koordinat_y integer,
      koordinat_x integer,
      geom geometry PRIMARY KEY
CREATE FUNCTION try_geometry_func () RETURNS trigger AS '
  BEGIN
      NEW.geometri = ST_GeomFromText('POINT(NEW.koordinat_y,
NEW.koordinat_x)',32748);
      RETURN NEW;
  END;
  ' LANGUAGE plpgsql;
CREATE TRIGGER try_geom_trg BEFORE INSERT OR UPDATE
      ON coba FOR EACH ROW
      EXECUTE PROCEDURE try_geometry_func ();
Name: Screen shot 2011-12-01 at 2.25.58 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111201/4c704ced/attachment.png>
